crank but won't turn over
hey so my friend has a 2000 Si, did a b20/V-TEC conversion. He was able to drive it back to his house but then the crank pulley fell off because the friend who installed the motor didn't put the crank pulley key in. The power steering belt fell off with it as well as the Alternator belt. Now the engine will crank but not turn over. Things we've checked:
spark plug wires,
battery,
spark plugs,
fuses
Does anyone have any idea what the problem might be? Do you think it could be the distributor?
spark plug wires,
battery,
spark plugs,
fuses
Re: crank but won't turn over
It could also be the distributor or the coil.
Also check that the engine is getting fuel. You said he drove it home so obviously that was working, except it is worth double checking.
so tried replacing ignition coil, nothing changed...as for the crank sensor, i will check...this is giving me a headache...
naw i dont think so, the sensor is located behind the plastic cover which is behind the pulley. i guess its worth checking. I tried looking everywhere for this same situation, but for some strange reason no one ever told about how they fixed it, or if they fixed it, so maybe this will be the first thread to figure out what it is!
or not lol
or not lol
so we got a p73 ecu, one of the wires dont fit so were gonna get a jumper harness (?) hopefully it turns over, after trying everything, except for checking main relay, this better work...
Jeremy Harris
21
05-02-2016 10:58 AM
accordinglyevil
01-11-2005 07:46 PM
