95 Ej1 w/B18B1 Swap PS Help....
Ok i recently swappped in a B18b1 into my ej1. Im trying to retain my Power Steering but cant seem to find out how. My problem is i have p72 brackets(i believe they are GSR) and the pump came off the same gsr also. So what would i need to keep my PS working. Ive searched and came to nothing except OB1 and OBD2 line diffirences and keeping it in a EK. But not Ej.
So any help would be greatly appreciated...Thanx in advance.
Re: 95 Ej1 w/B18B1 Swap PS Help....
Cool thats what i needed to know......You sure cuz this mguy at a "SHOP" said i had to cut my brackets to make it work? I was like WTH? No way ....ill find out. So i came on here. Thanx
What there saying bout you needing the upper LS bracket is correct since the pumps and lower bracket are the same. I just have all LS parts cause it came on my motor.
back to the top cuz i couldnt get it to work. The tensioner holes dont match up from the bracket to the pump? Why would this be? I was told it came from a GSR(the pump)
Im now running a top LS bracket and a bottom gsr....or so i was told the bracket came from with the pump.
Need help please...or could it be the belt? Cuz the belt is a GSR also. I can lift the pump up manually but no matter how high i lift it the belt stays loose.
Ok....im doing some research with belts and all and they are the same. The pump has a stamp .....P30A, is this correct? Or what am i looking at here.
TIA
TIA
Ok but where would it state this. I went to some spot and the pump said p30a on the castin but had a sticker where it said p72 and they were identical.
So by what do i go by? Sticker or casting?
I have no clue. I know my LS pump has a P72 sticker and my B16A pump has a P30A sticker. They are different P/N's , so I would think there has to be a difference, either externally or internally. Although you are right, they do look really similar.
jamessh1
10-04-2004 08:45 AM
not7fifteen
04-30-2002 10:26 AM
