Valve cover stud part #
Hey, I just want to know if anyone has the part number for the outer valve cover studs on a b16?
And the nut to, if they come separately.
Thanks
Thanks
Re: Valve cover stud part #
http://www.hondapartsunlimited.com/i...%20%28V-TEC%29
90012-PM7-000 BOLT B, HEAD COVER 1995 DEL SOL 4.22 2.95
I usually keep an extra one around
be very carefull putting these in...i broke two off when i first got my car so i ordered to from my local honda (there expensive as crap!) and snapped one of the brand new ones putting it in
Left hand drill dit and drill in reverse or weld a stud on the bolt. When i did my lift in my tahoe i blew a bolt and had to weld another bolt on to get it out
Call me Cheeks
That's what they make. Easy-outs for. If you can't use a screwdriver to turn it out then get a reverse drill bit or drill a small hole in it and beat a square easy out in it and turn it out.
Also if you dont have a welder just get 3 car batteries and hook em up in series. Kts redneck but works lol i dont own a welder so thats my arc welder
Call me Cheeks
I'm going to drill a small hole into the broken piece of the screw that's stuck in the valve cover and see if i can unscrew it. Is it likely that I further push the broken screw into the valve cover if I put too much force while drilling?
no it will evenually bottom out u wont hurt anything putting too much pressure on it. use wd-40 or motor oil to keep the bit cool it will drill faster and not burn the bit up if using a high speed
