Brake warning light stays on?
1995 honda civic ex with abs and have factory rear disc
hey guys i need help...i cannot figure out what wrong with my car...suddenly the brake light in the dashboard stay on...in the beginning it turns on then turn off...then it increase the time it stay on a lil longer...the car drives fine, brake work, and nothing seems wrong with the car....it just the light that bothering me...it late right now....so imma tried to find out what wrong with the car in the morning...so please help me out with the problem with my car...
thanks!!!!
thanks!!!!
Re: Brake warning light stays on?
not yet i know i have the brake reservoir and the abs reservoir should i check both..i never flush my abs reservoir ....thanks guys i check it when i get home and hopefully top it off..
hey fellas. THANKS ALOT!!!! problem solve no more warning light and my fluid was really low in the reservoir
really you only fixed the symptom. the problem is why is your brake fluid low. i would definitely try and figure out where it's leaking out at
hey guys thanks for the concern...i got bored this morning started to look around where the leak might happen and i found it...it was leaking on the right side brake line...had all these fluid spill in the wheel well...so i decide to replace both side with new one and bleed the reservoir...
supermotothud
11-10-2008 04:09 PM
