Blower Motor Question
I removed the blower assembly as well as my evaporator to install new a/c thermostat, and when I reinstalled it all, the blower still works, but I'm barely getting any air through the vents, what did I do or forget to hook up? I looked at it seems fine other than the air.
Re: Blower Motor Question
Make sure the blower is sealed correctly and you didnt remove any ducts..it will cause the air to escape somewhere else besides through your vents..
BUMP mode motor is working, it opens and closes the door when I change modes,just not enough air is getting out can't feel it on 1-3, only a bit on 4.
well i know when we ripped out my buddy's vents and all that in his civic when we did a harness swap and we had to get that foam tape stuff that goes around the vents from there it was only a couple dollars for a whole roll of it. i cant remember on the civics blower motors there should be a black hose on there that goes into the blower motors casing n then into the blower motor housing if there is check that
if its a different kind of seal u need the u will have to call a Honda dealer
below is the foam type
seal i am talking about
unclematt
11-14-2017 01:09 PM
