del sol engine swap troble
got a 1995 del sol and i just rebuilt my d16z6 the engine starts fine and will idle with no problems....once you try to drive it down the road it cuts out and eventually dies... It runs alright till it reaches normal operating temperature then dies and wont start til it sits for bout 15 minutes, i think it isnt gettin enough gas however i have changed the fuel filter taken the gas line off fuel filter and gas shoots out fuel pump is kicking on. Ive moved the distributor around all plugs and wires are new i took the catalyc converter off it isnt pluged up does anyone have any idead plz help
Re: del sol engine swap troble
the engine is grounded from the frame to my header exhaust bolt should i ground it somewhere else and i put the timing belt on because i had the head and everything off when i put this new engine togather i had all the arrows lined up right and rotated the belt twice and they were still lined up just like my honda book said to do
SunyaT23
04-17-2012 08:59 PM
TaSe
11-21-2008 07:00 AM
