is d16z6 and b16a1 wiring same?
im getting a free d16z6 and all associated wiring from a buddy who is parting his delsol out. im putting it in my 94 dx. after all the wiring is done and im back to work im planning on buying a b16 swap. with the wiring work with the b16 swap ? i know i will need to add a knock sensor but other than that will i be good to go as far as wiring is concerned?
thanks in advance
adam jeffery
thanks in advance
adam jeffery
Re: is d16z6 and b16a1 wiring same?
so will i have to add a wire from the shock tower to the ecu for the knock sensor for the d16z6 or is the wire already in the cabin harness?
thanks again
adam jeffery
thanks again
adam jeffery
Technical Hero
You'll have to wire either directly from the sensor to the ECU (what most people do) or run a wire from the sensor to the shock tower, then from the shock tower to the ECU
the.hamburglar
02-11-2006 11:36 AM
hj
10-29-2003 04:40 PM
