h22 in an eg civic?
h22 in an eg civic?
just a few questions about the h swap, is it possible to use the 92, 93 ..etc accord transmission, axles shift cables and such, and is there any other way to make factory mounts work for this swap instead of ordering hasport mounts.
Re: h22 in an eg civic?
on the tranny i have no idea for sure i would think so, cable yes those are the ones u want to use i did on mine, and no u have to buy mounts from a company i recommend Avid cheaper than hasport and alot easyier to install less chassis modds
90-93 trans will fit easily,. The bolt pattern on the mount is different. 94-02 F22 F23 trans will bolt right up if you use an H22 mount kit.
thanks for the info guys, so i can use the accord tranny, and for the mounts i have to buy them, and for axles, not sure what i would have to do there
BUY AVID mounts and what other guy is telling u if u use 90-93 accord tranny u will need a special trany mount that is not is a normal kit so buy 94-02 accord tranny make ur life easier
vy3tnamezz
08-31-2007 05:39 AM
Civichatch2k
08-09-2003 04:55 PM
