b series clutch problem
b16 trans steel braided line from slave to master. when im driving i have to let the clutch pedal off the floor a couple times before it will start to grab, well some times when I go to take off as soon as the pedal leaves the floor the clutch starts to engage but not fully. its only everyonce in a while but I dont know why it does this, its done it on multiple clutches and pressure plate combo's.
could my slave be going bad?
Re: b series clutch problem
Sounds like the spring on your pressure plate is messed up or binding. If it was bubbles in your system, the pedal may not come up, but at least the clutch would engage.
it happened in my rhd eg and my new eg. the only thing in common on the 2 cars were the same tranny, same slave same flywheel different master cylinder and both times I had a steel braided clutch line from master to slave
