*sohc guru's needed d15b help *ek*
96 ek hatch dx non vtec
swapping in d15b dual stage vtec -e
i have the p2j ecu
now how do i wire this thing up correctly because it does have TWO vtec solenoids
now the myths
if i use a 96-98 ex vtec harness i dont have to wire anything up?
if i use my dx non vtec harness i have to wire the vtc and knock sensor to the ecu?
what are the correct ecu pinouts?
starting this swap tomorrow 5-28-10
will add pics if the help is givin
hopefully this can become a good thread full of flicks and the right info..
i heard that this motor can be a economic monster
all help appreciated
lets get the info an swap started!!!
i have the p2j ecu
now the myths
Re: *sohc guru's needed d15b help *ek*
you do not have to wire for a knock sensor. it was included on the y7.
there is a guy that did this in his eg hatch.
http://www.causeforalarm.thecarthing...TEC/index.html
everything you need should be there.
good looks with the info but doesnt help me out.. this is a obd2 going into an obd2.. well looks like ima be working on it an tellin ya whats goin on cuz no one seems to have the info i am looking for
caan you take a boatload of pics to clear up everything, including the block code, head code, vtec solenoid, wiring harness connecting into the vtec solenoid, and the ecu. did you get an engine harness with the motor?
the redwhite sire goes to a21, just confirmed with my honda dealership
yes sir thank you.
dx harness u gotta wire up alotta stuff
bought a ex vtec harness
everything pluged up an rand the red vtec wire to a21
so far no cel an car running good
onesickej1
11-02-2009 01:56 PM
ekciviccoupe
07-14-2009 03:39 PM
