Engine Damper. Where does this bracket go?
Hey! Just wonder how does the little bracket in the j's racing engine damper go? I know the bigger bracket bolts down to the motor mount. Does anyone have a picture of this thing up close to where it mounts in an EK? THANKS!
^^ I figured dat much out. where does the bracket on the right side bolt to? It came with that black bolt for that bracket.
Re: Engine Damper. Where does this bracket go? (VolpeOwnsU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VolpeOwnsU »</TD></TR><TR><TD CLASS="quote">You guys notice a diff with these on there?</TD></TR></TABLE>
Guest
Posts: n/a
it goes back from where your brought it...and you take that money that you just wasted and put it to better use somewhere else
these things are WORTHLESS...and the ppl that say they aren't are the ppl that bought them for so damn much they THINK they work.
filled/solid mounts will do so much more for you tahn this ever will...and window weld is like $6 a tube
Re: (GSRswapandslow.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow. »</TD></TR><TR><TD CLASS="quote">it goes back from where your brought it...and you take that money that you just wasted and put it to better use somewhere else
filled/solid mounts will do so much more for you tahn this ever will...and window weld is like $6 a tube</TD></TR></TABLE>
okay. thanks.
Anyone know if it is okay for me to take out the upper control arm bolt? nothing is gonna happen to my upper control arm will it? do i need to raise my car up or anything? thanks for the help guys
okay. thanks.
Re: (JDM CTR EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM CTR EK »</TD></TR><TR><TD CLASS="quote">
okay. thanks.
Anyone know if it is okay for me to take out the upper control arm bolt? nothing is gonna happen to my upper control arm will it? do i need to raise my car up or anything? thanks for the help guys</TD></TR></TABLE>
I did notice a diffrence when I installed my engine damper, and yes you can remove the A-arm bolt with out jacking up the car. I did my at my friends body shop while it was parked on the ground, no problem.
okay. thanks.
RR98ITR
11
09-28-2005 10:53 PM
