Does any1 know anything about this engine...???
Hey guyz, this is my engine & im just wondering if this engine is any go0d...? Hos a pic of the engine & my car...!
http://img78.photobucket.com/a...2.jpg
http://img78.photobucket.com/a...0.jpg
Re: Does any1 know anything about this engine...??? (handa)
I think its called d16a 1.6litre... hmm if i wanted turbo, do i need 2 change internal parts...?
Re: Does any1 know anything about this engine...??? (Si1enzio)
If im not mistaken all D-Series engines are SOHC (single over head cam) besides the ZC but i dont think that is a d-series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 805ace »</TD></TR><TR><TD CLASS="quote">If im not mistaken all D-Series engines are SOHC (single over head cam) besides the ZC but i dont think that is a d-series.</TD></TR></TABLE>
the D16A1 is a DOHC non-VTEC motor.
they were produced in 86-89 integra's.
the DOHC ZC is it's JDM equivalent.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 805ace »</TD></TR><TR><TD CLASS="quote">no d16a is a SOHC and the one there is DOHC...</TD></TR></TABLE>
you're thinking of the D16A6, which came in 88-91 Civic Hatchback/CRX Si's.
you said its a D16A1 in your previous thread?
Modified by jL iLLuZiOnz 9 at 9:37 AM 6/9/2004
well its kinda odd for your car that is...it looks like a dohc zc swap (1.6 sohc non vtec)...pretty much the same motor from 89 integra...you said D series on the block correct...well then its not a B series ls swap...had this same swap in my crx a long while back...look at the valve cover...it has a detachable plastic cover over the cam gears....which all 90 and up LS valve cover are 1 peice aluminum cover covering the cam gears...thats why people cut that off so they can easily make adjustment to there adjustable cam
if u ask why this swap is in your car...it might be cuz of money...you can use basically everything from your original motor...i.e. tranny...don't know how they got around the dist. though...maybe used a obd1 ls dist. if that fits or just change from white plugs to grey plugs...but i can be wrong about the whole thing...but i highly doubt its an ls...hope that helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si1enzio »</TD></TR><TR><TD CLASS="quote">I think its called d16a 1.6litre... hmm if i wanted turbo, do i need 2 change internal parts...?</TD></TR></TABLE>
You are a complete Dumb ***... :
Please press ALT+F4 right now....
It's a LS motor.....B18b....Good for boosting because of low compression ratios, but no VTEC
Re: Does any1 know anything about this engine...??? (AsianEJ1Guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AsianEJ1Guy »</TD></TR><TR><TD CLASS="quote">
It's a LS motor.....B18b....Good for boosting because of low compression ratios, but no VTEC </TD></TR></TABLE>
thats pics is ur engine? ur car?=??
How do you know? it could be a d16a1.............i think we can eliminate the chance of it being a zc. on the zc, the cover over the cam gears is raised above the valve cover about an inch or so. but just go read your block
and you are...User Statistics
36 posts (0.65 posts per day on average)
AsianEJ1Guy last posted at 12:55 PM 6/9/2004
AsianEJ1Guy has been a member for 54 days.
You are a jackA$$. and need to read all the posts before posting....
[QUOTE=jL iLLuZiOnz 9]
you said its a D16A1 in your previous thread?QUOTE]
this is the corret info. thank you jL iLLuZiOnz 9
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si1enzio »</TD></TR><TR><TD CLASS="quote">Hmmm... Fair enuff... So how can i boost this engine up ehh ? </TD></TR></TABLE>
check here=> https://honda-tech.com/zeroforum?id=16
glad to have you with us
Riceboys at it again...thinking they know everything. If you read his location you would see he is in Australia. I'm not sure but I remember a thread a while ago about the 92-95 I think the Si and EX came with the DOHC ZC. Don't quote me on the models but I do remember they came stock. The DOHC ZCs do have a similar look to LS motors but I believe the distributors are a little different or something of the sort. So will YOU now Please press ALT+F4 and go into your Internet Options and make this a restricted site. Thank you and have a nice day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si1enzio »</TD></TR><TR><TD CLASS="quote">Hey guyz, this is my engine & im just wondering if this engine is any go0d...? Hos a pic of the engine & my car...!
http://img78.photobucket.com/a...0.jpg</TD></TR></TABLE>
Ok first of all if that is your car and that is your engine shouldnt you already know what that engine it is? because i see its a JDM and most people do already know so just look at the red spot where the guy highlighted for you and see what it says..... **** to me that can be anything (b18b, b20 block, or watever)
Re: Does any1 know anything about this engine...??? (Happyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyman »</TD></TR><TR><TD CLASS="quote">
Riceboys at it again...thinking they know everything. If you read his location you would see he is in Australia. I'm not sure but I remember a thread a while ago about the 92-95 I think the Si and EX came with the DOHC ZC. Don't quote me on the models but I do remember they came stock. The DOHC ZCs do have a similar look to LS motors but I believe the distributors are a little different or something of the sort. So will YOU now Please press ALT+F4 and go into your Internet Options and make this a restricted site. Thank you and have a nice day.</TD></TR></TABLE>
Yes I do know alot...
If your smart look in more detail about the engine, from what it looks like it's a LS DOHC motor... An just read the block and tell us so we can end this guessing game..
