Help Brake Swap Master Cylinder Fittings
The car 93 Hatch
The brakes 95 GSR w/ABS
The problem master cylinder has 12mm fitting/car has 10mm fitting
Ok after the fact we figured out that we should have used a non ABS master cylinder.
Has anyone cured this?
We went to Auto Zone and Advance Auto looking for a bushing or something that could work but they had nothing.
HELP DAILY Drive has no brakes.
Re: Help Brake Swap Master Cylinder Fittings (JohnnieChimpo)
you could PRACTICE flairing a 10mm fitting on a piece of similiar size brake line and see if you could do it. Cut off the flaired piece of brake line and slide off the 12mm fitting and slide on a 10mm fitting. Flair that newly cut off end with a flair wrench (with the fitting on) and viola, it solves your problem.
IHateJDM
08-23-2005 10:37 AM
t0eKnEe
10
05-26-2004 05:25 PM
