shock compatability question
Re: shock compatability question (moto27cm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moto27cm »</TD></TR><TR><TD CLASS="quote">To quote your sig, "yes".</TD></TR></TABLE>
thanks. so, all civic shocks and springs are independently interchangeable with integra shocks and springs?
Re: shock compatability question (verseone)
so, are they pretty much the same? is there a height difference between the shocks?
im implicitly implying the question: is it possible to have one integra shock in the front left and rear right, and civic shocks on the complementary sides w/out problems? Or without an awkward slant?
Re: shock compatability question (idrincwater)
hmm..good question...i compared my stock 94 civic shock to a stock 97 gsr shock and they looked identical..i've never mismatched them tho..i know integra spring rates are higher obviously to compensate for the weight of the car/motor..i'll check if they shocks are all the same part #
1 Post
the OEM shocks and struts are the same from the 94-01 TEGS (not ITR) and the 92-95 Civics - apring rates are different from the Civics to the Tegs - not sure about the difference between Civic CX, DX, EX, or Si and the Teg lineup.
Re: shock compatability question (93CivicSI)
well, i know all they are all the same between 94-01 tegs, except for type-r's. and i'm now beginning to think that the shocks are the same between 94-01 tegs and 92-95 civics. damn, i have that honda/acure eps cd somewhere in my room, but i can't find it. if i could just find it, i can check the part number. well in either case, i doubt that the springs would be the same also. shocks - probably, springs - i don't know. the reason i ask is because my girlfriend's front right shock blew, and i need to replace it for her. just seeing if i could use teg shocks for the job. in either case, thanks for the help fellas.
-eric
-eric
EG*MonKEY
07-08-2004 11:49 AM
