ECU Question
ECU Question
Can i use P28 from an automatic on my d16z6 manual swaP????? Or do i need the P28 from a manual???
Right now i'm running chiPPed only to activate vtec P06
Re: ECU Question (vtec25)
yes you can run it. yes you will throw a code, and yes there is a search button that will show you how to convert it so it dose not throw codes. Welcome to Honda-tech, where the search button is golden.
Re: ECU Question (sohcvtec1995)
i searched and found the info i was looking for but now i have new questions.
is it possible that i may be running lean with the p06??? and if i am running lean would i be back firing like i am now?? cuz i thought u only backfire when u run rich.
