BARO sensor
BARO sensor
Does anyone know where it is and how to fix it. I got the code for one but I dont know where it is. A pic would be appreciated along with the help. Thanks yo!
Re: BARO sensor (rainmanef)
the Boro sensor is built into the ECU for OBD1 ECUs. (I don't know about OBD2)
if you are OBD1, reset the ECU and try again... if it comes back up replace the ECU.
The BARO Sensor is a sensor that is on Euro Ecu's. You don't have to throw away your ecu, you can get it re-chipped and have that sensor disabled. Do a search under BARO and you will find all the info you'll need.
Re: BARO sensor (98HB)
Euro? The car is stock. Its a dx with an EX motor in it and when the swap was done, thats the code that I got. But thanks yo!
