case of disappearing coolant?
i got a h22 in my 93 cx and is currently throwing no CEL codes. my problem is that couple of days ago, my idle which sits at an even 1k, began flucutating between 800rpm and 1300rpm. i figured it was my coolant because i re-routed the coolant flow thru the TB straight to the thermostat. i bled the coolant after i did this mod, and filled the resevior up to the max. since then, coolant in the res. has just disappeared, and the rough idle comes and goes. i am lost about what to do. ive check for leaks and there are no puddles of coolant after or when its running. is it possilble that it couldve been the IACV? im lost help!
Re: case of disappearing coolant? (h22-cx-guy)
check the floor of your car. I had the same problem and the coolant was all over the floor of my car. Stupid heater core.
blue89hatch
09-06-2008 11:12 PM
