Removing TPS
Removing TPS
On a 94 LX, the TPS is located inback of the throttle body facing the firewall, and the connecter faces down. Is there a easy way to take it off, and is it difficult to reassemble. It looks like there are screws there, but they have no heads so im not realy sure on how to get it off. Thanks for your time
Re: Removing TPS (dr juice164)
use a dremel. why do you want to take it off? if you take it off and put it back on, you will need to set the volts again.
stackz
10-04-2006 07:06 AM
Vp Special K
04-08-2003 07:58 PM
