B18C obd2 into EG obd1 .....????????
Hello i have a us spec obd2 b18c5 .....i want to swap it into my Civic which currently has a 95 OBD1 B18b......i do not have the obd2 engine harness....
. 1 ...i just have the b18c long block with dizzy and alternator.....no intake manifold...but i have a aftermarket one and throttle body
.....2 ...what can i do to use the obd2 dizzy....or use my obd1 dizzy off the LS
.....3...any other sugguestions???? thank you....
ive done a couple of swaps...just never obd2 into obd1 car.....thank you
im in the same position, putting an obd2 h23 in a 95 cx hatch. you should be able to use the obd2 dizzy if you have the obd2 engine harness. but since you dont i dont know if you can use the dizzy. you can modify an obd2 harness to work with an obd1 dizzy so i would imagine you can do it the other way around too. as for the conversion harness if youre talking about the jumper harness thats just like a foot long good luck finding the one you need. i cant find one that goes from obd1-obd2. only the other way around. if hasport has one let me know cause ive searched their site and couldnt find anything that would work for me.
