buying b16, have a few questions
im buying a b16a2 off a 2000 SIR, i have a 1999 civic dx, is the swap basically a plug and play since my car is essentially the same as an Si(R), i know i have to wire for vtec, but can i use my stock harness, swap ecus and be done with it or are there different pinouts, and the engine comes with all mounts attached, i heard u need the rear tranny mount off an Si(R), so will that plug together, it also comes with the axles
is there anytihng else i need to make this swap happen, anything i should prepare for, thanks
when i did mine into my eg, i used the d series rear mount, and it came with the other two that i needed. ran vtec to the shock tower, and the knock sensor through the hole in the firewall. other than that, ur good (assuming its the same)
