idle problem please haelp
i got a 92 95 civic with a gsr swap . i just put a skunk 2 manifold in and after my idle is horrible . when i start my car it goes up to 2000 rpms then drops to 1200 and then starts to go up and down like theres a vacuum leak , but i smoked the engine to see if theres leaks but none where there . i dont know
Will you make something up for me please?
Re: idle problem please haelp (dstring20)
Check your throttle position sensor and your IAC. One or both of those is most likely your culprit.
Global Moderator
Re: idle problem please haelp (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo »</TD></TR><TR><TD CLASS="quote">Check your throttle position sensor and your IAC. One or both of those is most likely your culprit. </TD></TR></TABLE>
It may not be..
Did it do this before you did the IM swap?
If not then it has something to do with the install/swap
Spray water around the IM gasket and see if it bubbles, if it does then you have a vac leak.
goodluck and let us know y0!
It may not be..
wakajdm8732
12-15-2011 09:51 AM
builtsinglecam
04-27-2009 06:10 PM
