Del Sol dash swap into 95 civic
Del Sol dash swap into 95 civic questions?????
i've been searching all over H-t for info about a delsol dash into a 5th gen civic.
i found one topic with a couple pictures but not much explanation of it. just wondering if anyone else has tried it or knows someone who has or anything like that. any help or arrows in the right direction would be greatly appreciated.
yea i know a teg dash is more commonly swapped into a 5th gen but the delsol is a little different and i've got a decent hookup on one already if i can figure out how easy of a swap it is.
once again thanks for any and all help. if you cant help out dont post, thanks
Modified by 95dxhatch at 1:25 AM 9/8/2004
I sent the guy a PM via the forum we got here in Holland... so hopefully he'll respond here.
Marco als je wat hulp nodig heeft met het vertalen, pleur maar hiero neer en ik vertaal het wel inhet engels.
Just said if he has any difficulties with explaining it to do it in Dutch and I'll translate it for him.
Re: Del Sol dash swap into 95 civic questions????? (95dxhatch)
I have a few pics of this guys swap in progress from a previous thread but im at work right now so ill post them in the morning. Its only pics though nothing step by step
i dont need a step by step write up. just wondering how hard it was. i havent done a whole lot of wiring work just a lot of mechanical stuff like motor swap and suspension stuff. nothing with this much wiring involved.
heey that's my old ride..( and im proud off it..)
and yes i will give it a try..
and if there are some mistakes.. delvin will help you..
here we go..
to put a del sol dash in an hatchback you'll have to make some
corrections into the main wirring of the meter house.. cause the wirring is a bit diffrent..
( at the fusebox)
and you'll need an del sol airdirectioncap what's on top off the heating system..
it's that plastic thing on top off the heatingunit.
in the middle at the front off the car.. ( you still know what im talking about)
it's easely to remove.. just klink 2 or 3 clips and about 6 screws..
some off the screws are hard to get couse they're at the back off the cap..
you'll see it when your there
you'll need it because an civic dash has an
airoutlet on top and an del sol hasn't..
and some points to look at are:
on both sides the original mounths you'll have to make some holls..
because the sol dash has other mounting points.. you could use original sol mounthingbrackets.. but that won't fit easaly..
civic brackets don't fit either but is mutch less work..
i had made 2 holls in the brackets and whellded
2 nuts at the backside off them..
so that it would be easer to lock the bolts on them..
en between the bracket en the main frame (the car)
i put some distance rings.. so there is less thension at the dash.
.(sol dash is a bit smaller then a civic dash)
further you will have to disable the ground kabel at the steering unit..
and the cable off the heatingunit.. it's on the bottom off the heatingsystem
and on top off the del sol dash there is an mounthingpoint..
i haven't fixed that problem
and now its fidded in my other ride
im now working to make the midconsole( astray section)
fit propperly in the civic.. and that is a bitch.
. god damn that's not easy..
i will putt some pic's here when i finished it..
hmm i hope it makes sense what i put here..
and if you've more questions.. i will help..
maybe with some help from delvin..
it took me 15 minutes to write this hahha... arrrggghhh...
Modified by marcomhe1 at 12:28 AM 9/9/2004
Modified by marcomhe1 at 12:44 AM 9/9/2004
here we go..
( at the fusebox)
some pics off the swap
here you can see the plasit thing i mean.. it's on top off the heatingsystem.. this one is the civic one..
and this shows what have to be done.. a lot off work..
Re: Del Sol dash swap into 95 civic questions????? (marcomhe1)
hey do you have any more pics of that exhaust on your hatch i like it what brand or is it custom.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marcomhe1 »</TD></TR><TR><TD CLASS="quote">
and this shows what have to be done.. a lot off work..</TD></TR></TABLE>
Dude - nice ****** Civic!! I like it!
Re: Del Sol dash swap into 95 civic questions????? (YOUR MAMA)
well that civic is exit.. because my ex girlfriend had an accident..
and the exhaust it's a muffler that everybody can buy.. and normaly it's position at the right.. but i've whellded some things so it's in the middle..
maybe i should make an topic about my ride..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YOUR MAMA »</TD></TR><TR><TD CLASS="quote">
Me too!
Reminds me of a Mk4 Golf from that angle
Me too!
Re: Del Sol dash swap into 95 civic questions????? (al3e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by al3e »</TD></TR><TR><TD CLASS="quote">cool thing bout the del sol dash... u got the deck hider thingy flipper majigger.. ha! </TD></TR></TABLE>
i love that thingy flipper majigger. its like a security feature and yet it makes the interior look CLEAN
Re: (twinturbobb)
that's the banner of our club.. hahahha..
and the brand of the lip i don't know.. i'll get some information for you.. i know it is the last one in the netherlands..
Modified by marcomhe1 at 8:32 PM 9/9/2004
Re: (twinturbobb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twinturbobb »</TD></TR><TR><TD CLASS="quote">dang, thats what you get for putting that rice banner on your car!!!!</TD></TR></TABLE>
HAHAHAHA sheesh great way to dis the club...
**** marcos last Civic had the worst luck ever... and the curse has carried on to his new Civic... the grey one got side swiped by some bitch that ran a red light... marcos had what.. 4 5 crashes with his Civics...
Here's his latest striping.
Marco is our very own crash test dummy... JDM is way to overrated HAHAHAHA
It's all good though she's goin thru a rough spell at this point but shes goin in for a makeover come this winter.. hopefully this summer she'll be back in all her beauty next summer.
Guest
Posts: n/a
Re: (Del"TheSolMan")
Wow, looks like you have some work to do on that new Civic... nice theme with the stickers, hahaha
Sucks to hear about the gray one, euro style is so much better than anything we have over here, but did the bitch who sideswiped him ruin 2 of his wheels?
I actually have family in Heerlen, NL (but they are polish), very beautiful place
Re: (YOUR MAMA)
euro style is so much better than anything we have over here</TD></TR></TABLE>
gross, euro cars are wierd looking
Re: (YOUR MAMA)
my tires where completely worn.. and now i do'nt have the money.(ex girlfriend troubles.. women grr). and the civic is looking like ****.. so i thought hmm i've got 2 vtec rims.. with good tire's.. it will fit in the picture hehehe..
hmm heerlen.. that's right on the corner.. but netherlands it's very little.. you can drive in 4-5 hours accros the whole country..
