yes..yes another b16a1-eg swap??
Like the title says.. I have searched but with very little success I need to know if there is a good write up on swaping a b16a1 out of my crx into my new 1995 eg. About 90% of the post's that i looked at ended with use the search. so after searching for 2 or 3 days i need someones help. I know everyone is going to say sell the a1 and get an a2....but im in no rush to swap the motor because im going to prep it for a turbo.
sweet, thats a great write up but what bout the obd0 to obd1 switch with the p72 ecu, obd1 dizzy and the part that i did not get was when some one said swaping to a obd1 intakemanifold.....would one from a del sol work.
Re: (tallguy)
im actually doing it right now. you need the following:
obd-1 b16 or type r intake manifold, throttle body injectors
p30 ecu or chipped p28
gsr drivers side mounting bracket and mount
obd-1 distributor
gsr rear L bracket
gsr front tranny mount
thats pretty much it.
obd-1 distributor
gsr rear L bracket
Re: (tallguy)
you will also need the wiring harness from an obd1 car. if you have the harness from the del sol then you should be alright
Re: (Lmgrcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lmgrcivic »</TD></TR><TR><TD CLASS="quote">whats the difference between the OBD0 and the OBD1 intake manifolds jw</TD></TR></TABLE>
the obd0 has alot of vacume lines and ****. the obd1 will look alot cleaner and you need it to pass the ref if you are in cali like me
