Ball joint removal...search is down
Im having trouble removing the lower control arm from the ball joint on my friends EG and i need help of way doing it...the FAQ axle replacment thing wasnt much help on the ball joint subject.
Re: Ball joint removal...search is down (rwcdrums)
Re: Ball joint removal...search is down (komat)
thanks komat thats exactly what i was lookin for, cuz i saw it yesterday...thanks
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
Re: Ball joint removal...search is down (b16crxkid)
i just did a five lug conversion. i actually undid most of them by propane torching the end of the arm and not hitting the grease boot with the flame. if you heat it long enough (expansion), the shock spring pressure popped the arm off the joint without even hitting it . if it doesn't pop, then a slight tap gets her off.
Vp Special K
17
01-06-2004 02:08 PM
