misfire dealer cannot fix it
I just have someone did a swap of a 2001 gsr into 2000 Lx civic. I use the 2000 si harness and 2001 gsr ecu. Random misfiring in 4 cylinder. Change the ignition wire. spark plug. distrubitor, and fuel regulator. Check the fuel pressure, injectors, map sensors, no problem with them. Then take it to the acura dealer and have valve adjustment. Still did not fix the problem. Don't know what to do. Need some serious help. Thanks
Mr. Badwrench
Re: misfire dealer cannot fix it (_Edge.ONE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Edge.ONE »</TD></TR><TR><TD CLASS="quote">Did you check compression?</TD></TR></TABLE>
i would start there then if thats low a cylinder differential pressure test. (leak down)
Re: misfire dealer cannot fix it (dayaftertomorrow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dayaftertomorrow »</TD></TR><TR><TD CLASS="quote">light load. I did a compression test and all 4 cylinders are fine. Thanks</TD></TR></TABLE>
did you do a running compression? if it is isolated to one cylinder, check the plugs, and other parts related to cylinder that has the problem.
Re: misfire dealer cannot fix it (BatuKing)
Since you pretty much replaced your whole ignition system,all that leaves is fuel and or/ mechanical problems...
Id try running some sort of intake system cleaner such as Seafoam or BG through the intake to clean any buildup on the valves...If that doesnt help,swap injectors from the affected cylinder w/ another and see if it follows it...
No other codes right?
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dayaftertomorrow »</TD></TR><TR><TD CLASS="quote">what is a low a cylinder differential pressure test. (leak down). Thanks</TD></TR></TABLE>
anything more than 15% difference.
Re: misfire dealer cannot fix it (PyroProblem)
it a 2001 engine with 36,000 miles. The fuel pressure is fine and for the injectors, are all b series engine the same?
markopolo
03-05-2017 06:16 AM
