Spoon caliper compatibility?
Old 02-19-2005, 12:46 PM
mdd
mdd's Avatar
Default Spoon caliper compatibility?
Hi,
I was wondering can you use the spoon calipers with stock civic dx 4 x100 brake assemblies? Also can you use them with the 4x 114.3 itr 96 spec assemblies? Thanks for the help
Old 02-19-2005, 01:10 PM
niterida's Avatar
Default Re: Spoon caliper compatibility? (mdd)
yes you can get them to fit
but you need an adapter from aj-racing.com
Old 02-19-2005, 01:25 PM
mdd
mdd's Avatar
thanks wasnt sure cause i looked at the spoonsport us website and it only said ek9 ( i was guessing for 5 lug ctr), and (98 spec itr). Thanks again
Old 02-19-2005, 02:38 PM
slammed_93_hatch's Avatar
Default Re: (mdd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mdd &raquo;</TD></TR><TR><TD CLASS="quote">Hi,
I was wondering can you use the spoon calipers with stock civic dx 4 x100 brake assemblies? Also can you use them with the 4x 114.3 itr 96 spec assemblies? Thanks for the help</TD></TR></TABLE>
you can't use them with the civic DX setup, the spindel is a different size and you can't get a 11.1" rotor to mount up to the spindel so then you can't use that caliper.
You can do it with the 4x114.3 ITR suspension though since that spindel can accept a 11.1" rotor, and it shares the same spindel as the 5 lug ITR just a different hub
Old 02-19-2005, 02:39 PM
As long as I dont have to take out any more Metal Gears
rukawa1one's Avatar
Default Re: (slammed_93_hatch)
I think u may have to run a 16 inch rim as well, not sure though
Old 02-19-2005, 02:42 PM
mdd
mdd's Avatar
So it wont work with the stock civic or gsr hub and rotors?
But will work with the 96 spec ITR rotor and hubs without brakets and longer studs etc? I thought the gsr brake assembly shared teh same rotors as the 96 spec ITR rotor just different sized calips.
Let me know but thanks for the help so far i appreciate it :D
Old 02-19-2005, 02:44 PM
mdd
mdd's Avatar
Default Re: (rukawa1one)
16'' rims are ok i plan on doing that anyways but yeah I am just not sure how to get it to work without having to upgrade to a 5 lug ctr or itr suspension... Cause if thats the case I would rather just get a different brand bbk that would be cheaper.
Old 02-19-2005, 02:55 PM
Default Re: (mdd)
no it will work with the fallowing.
94-01 integra RS/GS/LS/GSR
94-95- civic SI/EX WITH ABS
96- JDM ITR 4x114.3
Now as far as rotors go well the integra and civic you will need to get either some fastbrake honda 11.1inch rotor, or source your own.
for the 96 JDM ITR conversion you will need 93-97 (i think not sure on the generation) prelude vtec calipers and it will work. Spoon actually sold a conversion kit with these calipers, and some one had it for sale in the classifieds about 6 months ago
b18_crx
03-14-2017 05:32 PM
b18_crx
03-14-2017 10:23 AM
crdizzle6288
05-31-2007 08:56 AM
strepto
02-24-2004 11:50 AM
Denny
01-14-2004 03:44 PM
Quick Reply: Spoon caliper compatibility?
