How do i make a 4 wire o2 sensor engin work with a 5 wire o2 senor (civic VX)
I need help, i have a 92 civic vc and i put the si vtec motor in it and the computer that came with the motor doesnt work properly and when i put the vx computer in it works ok but not great. How do i fix that problem? do i need to change my 5 wire to 4 wire?? help me pls
Re: How do i make a 4 wire o2 sensor engin work with a 5 wire o2 senor (IHateJDM)
I tryed that. the 4 wire o2 sensor doesnt fit in to the plug of the 5 wire
Re: How do i make a 4 wire o2 sensor engin work with a 5 wire o2 senor (DaveFazari)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveFazari »</TD></TR><TR><TD CLASS="quote">I tryed that. the 4 wire o2 sensor doesnt fit in to the plug of the 5 wire
you need to change the plug, or just solder it in.
Mr. Badwrench
i used this on a 1 to 4 wire conversion, but i would think it would be the same. i used it and it worked flawlessly.
http://www.hybridautomotive.com/tech/o2/#seven
Re: How do i make a 4 wire o2 sensor engin work with a 5 wire o2 senor (boostedcivicsir)
Thanks, then do you think that the computer i want to put in will work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveFazari »</TD></TR><TR><TD CLASS="quote">Thanks, then do you think that the computer i want to put in will work?
what is the ecu code?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">http://www.hybridautomotive.com/tech/o2/#seven</TD></TR></TABLE>
I used that for my VX to EX o2 wiring. Works perfect!
randyqnt
10-16-2008 08:08 AM
SPOON_BeIgHtEeNsEe
03-03-2008 03:26 AM
