Help!! what's needed for b-series swap in 95 Dx?
Re: Help!! what's needed for b-series swap in 95 Dx? (BoRiCuA)
what kind of b series? vtec or non vtec? non-vtec ls is easiest and all you'll need is axles, motor, tranny, harness, mounts, and an eshaust upgrade. keep in mind that you can still use your DX ECU but it'll lack power. i suggest a P28 or a P30 ECU
Re: Help!! what's needed for b-series swap in 95 Dx? (Type-X)
ok how's about a d16 vtec? do i have to change the harness or any mounts? thanks
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoRiCuA »</TD></TR><TR><TD CLASS="quote">ok how's about a d16 vtec? do i have to change the harness or any mounts? thanks </TD></TR></TABLE>
you can use the same harness or the one that comes with d16z6. you will need to run vtec wires though unless your chassis is a 92
Re: Help!! what's needed for b-series swap in 95 Dx? (hatchi)
so the only thing is the harness and wire vtec, but wait it's not multi point fuel injection it's a dx, does that matter what about ecu can i use the p06 with z6?
MGBej1503
05-06-2012 11:00 AM
nemesis25
18
11-01-2008 07:36 PM
