Clicking noise when first moving my car in morning
When I first start my car in the morning, everything is fine. I let it warm up, back out, and go. When I first go in the morning, the car clicks as it's going. After a few minutes, it quits. Can anyone help me troubleshoot this? Thanks!
Lowd
Lowd
Re: Clicking noise when first moving my car in morning (loclowd)
do you know where the click is coming from?
would be easier to diagnose with that information
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loclowd »</TD></TR><TR><TD CLASS="quote">When I first start my car in the morning, everything is fine. I let it warm up, back out, and go. When I first go in the morning, the car clicks as it's going. After a few minutes, it quits. Can anyone help me troubleshoot this? Thanks!
Lowd</TD></TR></TABLE>
I had an LS integra that did the same thing. I changed the timing belt, water pump, and adjusted the valves and then had no more problems with the noise, my GSR just started doing the same thing so i guess i'll be doing this procedure on that car aswell.
Re: Clicking noise when first moving my car in morning (drtyhatch)
Could be the valves, injectors or 'piston slap'. All are pretty common noises on Honda I-4s when cold (and sometimes even warm). I'd adjust the valves and see if that helps.
Whats the milage of the car? Above 80k change the timing belt and adjust the valves. (change the water pump with the belt) how cold are the mornings where your at?
Re: Clicking noise when first moving my car in morning (robbieshonda)
The clicking noise is only when I start to move, not Revving the motor up.
It's not too cold hear in VA Beach.
KS3421
05-16-2012 08:48 PM
loclowd
10
10-12-2005 05:06 PM
