D16Y8 Heads
Old 10-11-2005, 10:33 PM
biggnubbs's Avatar
Default D16Y8 Heads
Ok so im kinda a noob at this and I need some help I have a 97 HX with the CVT automatic trans and I wanna do a Y8 head swap what problems might I run into or, what things might I have to get for it to work right?
Old 10-12-2005, 07:35 PM
specv5150's Avatar
Default Re: D16Y8 Heads (biggnubbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggnubbs &raquo;</TD></TR><TR><TD CLASS="quote">Ok so im kinda a noob at this and I need some help I have a 97 HX with the CVT automatic trans and I wanna do a Y8 head swap what problems might I run into or, what things might I have to get for it to work right? </TD></TR></TABLE>
wiring harness
oxygen sensor
ecu
tranny
I am not too familiar with CVT's but I dont think any other ECU can run it. Not sure though. The Y8 runs on 4wire oxygen sensor so you will have to change that. To run the Y8 properly, you will need a EX ECU. To get the full potential, you should change the tranny as well. There is no point in swapping unless you plan to go all the way
Old 10-12-2005, 07:56 PM
FuNkDrSpOt's Avatar
you need to wire up vtec
ecu
y8 head (of course)
y8 dizzy
I didnt see anything about needing O2 sensors, a tranny or a wiring harness.
I'll point you here to get more info:
https://honda-tech.com/zerothread?id=735196
Btw, i have a full vtec swap available, click my sig for pics
Old 10-12-2005, 08:01 PM
specv5150's Avatar
Default Re: D16Y8 Heads (FuNkDrSpOt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt &raquo;</TD></TR><TR><TD CLASS="quote">
ecu
y8 head (of course)
y8 dizzy
Btw, i have a full vtec swap available, click my sig for pics</TD></TR></TABLE>
Before you try to educate people you should know that write up is for a Y7/Y8 type mini-me. Y5 is a different beast. Y5 is already wired for VTEC since the Y5 is VTEC-E. And he WILL need an oxygen sensor since Y8 is 4wire and Y5 is 5wire. I ran a 4wire ECU (P28) with a 5wire oxygen sensor and it ran but like **** AND I would stall at stops. AND the CVT is not like any other automatic honda transmission and I dont think it will run off any other ECU. I am not 100% on that but fairly sure. He wont need a wiring harness but it might be easier unless he is skilled at wiring
Old 10-12-2005, 08:19 PM
FuNkDrSpOt's Avatar
Default Re: D16Y8 Heads (specv5150)
I bow to your infinite wisdom......
Old 10-12-2005, 09:15 PM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt &raquo;</TD></TR><TR><TD CLASS="quote">I bow to your infinite wisdom...... </TD></TR></TABLE>
I wasnt trying to be an ***, just pointing out what I know. My wisdom is far from infinite
Lasty K
27
11-01-2017 09:03 AM
cbabyby
10-09-2009 02:17 PM
chickenwing
10-26-2008 05:05 AM
HondaHemi
10
02-08-2006 01:02 AM
AGENT 99
25
09-15-2004 09:00 AM
Quick Reply: D16Y8 Heads
