ECT Switch Help!
ECT Switch Help!
Does anyone know the pinout of the ECT switch on a D16Y8? I need the switch that's on the thermostat housing. I have a shop manual, but for some reason it just shows the ECT sensor and sending unit. Thanks in advance for any help.
Re: ECT Switch Help! (makavelli1227)
its only two wires right? one for ground one for power? Check try both.. if i had a diagram id be of more help but i dont sorry.. should be around 5 volts..
Re: ECT Switch Help! (JDMOrangeFever)
The problem that i'm having is I can't find the sensor itself. I want to know the wire colors so I can go to the ecu and trace it back through the wire harness and try and find out what happened to the sensor.
Turbo EH2
09-29-2006 04:03 PM
