code 10-IAT sensor
Old Feb 9, 2006 | 05:21 PM
strtciv93's Avatar
Default code 10-IAT sensor
Hey guys could someone help me out I have a code 10 CEL light which is -IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor-
I dont know where this sensor is or how to test if it is still good or not. Can anybody post up a pic of where its at on a z6 or at least tell me where i can find the thing?
Old Feb 9, 2006 | 05:56 PM
strtciv93's Avatar
bump for some help plz
Old Feb 9, 2006 | 06:23 PM
ILoveJDM.'s Avatar
The IAT sensor is on your intake manifold... It is on the drivers side and is just a plug that is visible... You must check the power to the plug, although if youre recieving this code, I would replace, it is cheap and easy to fix. I will give you a link to a Z6 motor with the IAT, and a few other sensors... The IAT is the Intake Air Temperature, just 2 phillips screws you must remove, but watch to not strip them, if you do, you can use a dremel tool to cut into. Hope this helps.
http://www.honda-acura.net/for...28271
SoHc94
Sep 11, 2006 08:58 PM
buddy jonez
Apr 4, 2005 09:25 PM
Phaulkyou
Oct 13, 2003 04:35 PM
DLB1994
Aug 18, 2002 03:29 PM
