What could be causing this monster of a smoke screen?
I'll make this quick and to the point.
Engine: D16Z6
When Idle: car will idle fine with no smoke coming from the tailpipe
After idling for a bit (ie. at a stop light), then taking off under normal acceleration: James Bond-type smoke screen comes out from the tail pipe.
Normal driving: no smoke, looks like a normal car
Compression #s: 205, 204, 201, 203
Color: Blueish-white smoke
So my question is, what could be causing it to burn oil?
Engine: D16Z6
Re: What could be causing this monster of a smoke screen? (Street Ghost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Street Ghost »</TD></TR><TR><TD CLASS="quote">
So my question is, what could be causing it to burn oil?</TD></TR></TABLE>
Is it overfilled?
Is it overfilled?
Re: What could be causing this monster of a smoke screen? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
Is it overfilled?</TD></TR></TABLE>
Not overfilled. It was actually between the two dots on level ground so I filled it until it was right under the top dot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN »</TD></TR><TR><TD CLASS="quote">have you check or change the oil?? what color?</TD></TR></TABLE>
Oil was changed 18 miles ago along with the filter. The color of the oil id clear light brown. The color of the smoke is blueish-white.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 »</TD></TR><TR><TD CLASS="quote">PCV Valve clogged. Replace $2 dollars total.</TD></TR></TABLE>
I will try that.
Keep the suggestions comin`
I will try that.
Re: What could be causing this monster of a smoke screen? (fms1day)
Here's a vid of what I mean: http://www.jhu1986.com/videos/Movie.wmv (Right click, Save As..)
Re: (Jmunk)
This happened to my friends car, his brother is a honda mechanic and he did two things to his car, first was he told him to change the EGR valve, then it was still doing it a lil bit so then he made him use thicker motor oil, it stopped now. So you might be burning oil somewhere.
Does it smoke when you start the car in the morning? Might not be so bad as rings, probably just valve seals. Your car will only smoke when you peel off. However, if its rings as well you will see it when your reving to high rpms
My eclipse had the SAME EXACT PROBLEM - its your ring bud. Thicker oil will help - like the guy said, or buy no smoke treatment (SUPER THICK)
Could be a valve seal too though.
1 Post
Re: (dogbiscuit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dogbiscuit »</TD></TR><TR><TD CLASS="quote">around here that's called winter.</TD></TR></TABLE>
Ummm... No.
Ummm... No.
Re: (dogbiscuit)
Please don't post if you don't have anything intelligent to contribute.
To all others.. we'll try running thicker oil. Right now, it's using 5W-30 Honda oil.
Re: (saxman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saxman »</TD></TR><TR><TD CLASS="quote">valve seals tend to show up as smoking when you lift your foot off the gas after accelerating.</TD></TR></TABLE>
true, seeing as his compression seems consistant. Rebuild time?
Re: (Eyal 951)
I've got bad valve seals on my car, it doesnt throw up a james bond type smoke screen. Plus, it smokes at idle, not so much when you get on it.
Go get a leak down test and see if your rings are bad.
Re: (ck123)
Could be a headgasket but with head gaskets you will usually notice either a loss of coolant, milky looking oil, or the car overheating while sitting or city driving.
Re: (eXcelonTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eXcelonTypeR »</TD></TR><TR><TD CLASS="quote">I second the leakdown testing.</TD></TR></TABLE>
same here. that will help you find the problem. if its not rings its possibly your valve seals
