Prothane Motor Mount Inserts
I am wondering which Prothane Motor Mount Inserts I need. I have a 95 civic hatch with a b16 in it. Do I buy them for a 92-95 civic or do I buy them for a 99-00 SI for the motor.
Thanks
Thanks
Re: Prothane Motor Mount Inserts (mxpx035)
i am using the motor mounts the came with the b16a (complete swap from hmotors)
Integra upper drivers side mount is different than a b16
Re: Prothane Motor Mount Inserts (CALIdelsolSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CALIdelsolSIR »</TD></TR><TR><TD CLASS="quote">get them for a 93-95 DOHC VTEC Del Sol. Problem Solved.</TD></TR></TABLE>
I'll have to agree with this one also!
Re: Prothane Motor Mount Inserts (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle »</TD></TR><TR><TD CLASS="quote">which motor mounts are you using? those are the ones you buy.</TD></TR></TABLE>
did that sentence make sense ? not sure what you are asking. go with energy, good inserts for cheap.
Also the inserts are gonna rattle your teeth out. If the car is driven daily, you might want to look at just a torque damper. It depends on what your looking at doing.
Re: (hondafan62269)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondafan62269 »</TD></TR><TR><TD CLASS="quote">94+ Integra inserts.</TD></TR></TABLE>
if you are using eg mounts the inserts for the 94-01 teg are gonna be a little differant but you can cut them to work.....best to just figure out which torque mounts you have and use the right ones. if you dont know than just buy the eg ones and check it out.
