All 92-95 antennas retract to the antenna plate?
Does the antenna on a 95 Vx go all the way down to the plate? Mine sticks out about 10" and does not want to retract anymore
I know my 93 Cx went all the down to the plate
HT Order of Merit
Re: All 92-95 antennas retract to the antenna plate? (Hybrid93Hatch)
Yea they all should go all the way down. Put some silicone on a rag, pull the antenna out and wipe it down. It should slide all the way down.
Re: All 92-95 antennas retract to the antenna plate? (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">Mine doesn't on my VX</TD></TR></TABLE>
It's the largest part (base) of the antenna right? The rest retract. About 10" that sticks out?
I'm going to look at it again when I get home. I've got to either get it flush or remove the damn thing
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch »</TD></TR><TR><TD CLASS="quote">
I'm going to look at it again when I get home. I've got to either get it flush or remove the damn thing </TD></TR></TABLE>
Yeah like the piece that is "thicker" doesn't budge.
if it was bent even slightly during it's life it will stick. REALLY sucks, mine stuck out about 3 inches on the larger part and I couldn't pull it out or push it in.
I ripped out the antena and welded the hole shut when I repainted, no more problem.
Re: (dohcdelsol)
I don't see anyway the antenna can retract any further then we speak of. Has anyone successfully removed the antenna from the plate / swapped in an antenna that retracts completely?
Re: (Hybrid93Hatch)
Up because I would like to replace the antenna with a block off plate
Is the antenna held in place behind the A-pilar?
I have a 93 si hatch, a 95 si hatch and a 92 cx hatch and all three antenas go all the way down. I think yours must be bent or is stuck because of grime try some silicone spray and twist it.
you can do what i did. One my GF's si hatch here antenna cable broke off, so i replaced the antena with one i had sitting around,but instead of haveing it int he stock location, I put it behind the dash, now she just needs the block off plate. looks alot cleaner..
tobe1424
14
06-11-2006 09:27 PM
IloveAPC
31
11-25-2004 06:24 PM
