just baught a jdm b16a swap!!!!
so i got a b16a swap.. its a obd1 engine and i have a obd1 wire harness laying around un cut..i was wondering if it would wire right up..vtec and all..also..wat kind of axles should i get...linkage?..radiator..and was a decent souding..not too loud but deep enough to hear a block away...headers to the tip...? i already orderd engine mounts and clutch cylinder..wat else would i need for this swap to be complete? thanks!
Re: just baught a jdm b16a swap!!!! (v8 integra)
you have to use the ex harness from your car. and then get a obd-2 distributor, injectors, and alternator. after you get that you should be ready to go. and for the axles, you can use 94-01 integra or 99-00 civic SI. same with the shift linkage
Re: (b16egva)
Just did this exact same swap in to the exact same car. First off, did you get a full swap from anywhere or did you just piece this whole thing togeather? I got the full swap from HMotorsOnline.com and that includes the right axels(Del Sol VTEC I believe.) Your gonna need a conversion harness OBD2a - OBD1 (JDMShit.com has em for cheap.) Integra LS linkage i believe is what you need. The radiator you have can work, you need Del Sol hoses though. Heres a link to a write up from a guy who did this exact swap.
http://hybrid.honda-perf.org/t....html
Hope this helps bro!
Jdmhondaowner
07-17-2014 01:59 PM
xwhitchx
08-27-2009 07:06 PM
b18 hatch mike
06-12-2007 05:58 PM
da_rimrocka
11
12-08-2005 07:51 AM
vidanator
01-24-2005 01:27 AM
