something burnt when im blasting it
Old 04-14-2006, 09:42 PM
ZipTieGUy's Avatar
Default something burnt when im blasting it
i was pullin to redline in 3rd today and mashing it then i started smelling something burning coming out my vents. what could it be/. stock d16z6
Old 04-14-2006, 09:44 PM
SOHC4life 96's Avatar
Default Re: something burnt when im blasting it (ZipTieGuy)
Could be the clutch starting to go. You need to give us more information though. What kind of smell?
Old 04-14-2006, 09:59 PM
KoLRaNcH's Avatar
Default Re: something burnt when im blasting it (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">What kind of smell?</TD></TR></TABLE>
Old 04-14-2006, 10:06 PM
crashedacar's Avatar
it could be a few things.
1 my guess is the clutch might be slipping.
if so ull probly need to replace it.
2 might wanna check around the bay see if ur leaking oil.
if so replace seals etc.
3 also check ur hoses it shouldnt be a problem but u might be leaking colant on ur block. if that is the case and they arent cracking then just go head and make sure they are tighten down.
i have had all of these problems in the past with another car. good luck. hope i helped.
Modified by crashedacar at 11:19 PM 4/14/2006
Old 04-14-2006, 11:50 PM
thahuhstunna's Avatar
Default Re: something burnt when im blasting it (crashedacar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crashedacar &raquo;</TD></TR><TR><TD CLASS="quote"> it could be a few things.
Modified by crashedacar at 11:19 PM 4/14/2006</TD></TR></TABLE>
i really doubt these reasons, personally i would like to kno if you had defroster/heater/anything like this on, just to see if it's the heater core,aside from that, it's likely oil, in which case it could be a variety of things, but coolant has a very distinct smell and if a hose is going, you'llknow by the billows of smoke fromunder the hood...good luck keep us posted
Old 04-15-2006, 01:46 AM
ZipTieGUy's Avatar
doesnt smell like oil.. or coolant either. kinda smells a little like the clutch but not really. smells a little rubbery.
the thing is that the smell came straight through the vents so i dont think its coming from the tranny. no smoke anywhere. car runs coo but it got 188k on the motor and i know compression is not as great as it should be
could the clutch be slipping but my rpms didnt jump or anything
Old 04-15-2006, 02:29 AM
E46Kid's Avatar
yup!
Old 04-15-2006, 03:43 AM
Mohsin's Avatar
usual suspects are CAT / Clutch.
Old 04-15-2006, 06:51 PM
Default Re: (Mohsin)
haha. my bad i didnt fully read the first post. my bad.
Old 04-15-2006, 10:30 PM
mr cx hatch's Avatar
Default Re: (crashedacar)
it was probably the exhaust from the guy in front of you.. that you were racin'
the ludee
04-23-2008 06:00 PM
EvilCamaroSS
04-07-2007 01:32 PM
teggy2154
11-15-2005 10:33 PM
Endoe
02-08-2005 10:21 AM
Airmax55555
12-29-2003 01:35 AM
Quick Reply: something burnt when im blasting it
