HELP: Check Engine Light
disconnect the negative battery terminal for 20 mins or so will clear the ECU....
If it doesn't shut off after you start it back up, then u can't shut it off until you fix the problem that's causing it..
Refer to the codes stick post at the top of this forum for information on pulling codes w/o a computer
parisbaby
10-22-2017 03:24 PM
