Radiator help!!!!
Radiator help!!!!
I have a 94 civic with a b16 my radiator has a crack so I went to discount to buy another 1 and it looks exactly the same except the inlet on mine is 1 1/4 and the discount 1 is 1 1/8 and its the same on all yr civics...I tried to just tighten the clamp tighter but it still leaked.... Help!!!!!
Re: (hondachris1994)
I even ordered radiator hoses from a 99 civic SI and the upper hose was 1 1/4 and the lower was 1 1/8 inle and my motor has both 1 1/4 on motor side and they sell me a radiator that is 1 1/8 on upper and lower WTF!!!!
Re: (ZipTieGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZipTieGuy »</TD></TR><TR><TD CLASS="quote">i guess you can get a smaller hose since you already bought a raditor.</TD></TR></TABLE>no I cant cause it would have to b different sizes on each side of the hose...1 1/4 motor side 1 1/8 radiator side
my roommate did something like that for his swap (it was temporary but it worked)
He took a piece of the smaller hose and slipped it over the radiator fitting and then put the bigger hose over the smaller hose and it worked! But like I said it was only temporary
Re: (wheelmanbg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wheelmanbg »</TD></TR><TR><TD CLASS="quote">my roommate did something like that for his swap (it was temporary but it worked)
He took a piece of the smaller hose and slipped it over the radiator fitting and then put the bigger hose over the smaller hose and it worked! But like I said it was only temporary</TD></TR></TABLE>I might try that, but ima go to autzone and c if there radiator is the same inlet, I think discount sucks IMO
Man I had the same problem with Autozone, I gave up and went to Honda and bought a radiator for a civic si. It cost about $225 but I went back to Autozone 4 times and they still couldnt get it right, with the radiator or hoses.
Re: (93Civac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93Civac »</TD></TR><TR><TD CLASS="quote">Man I had the same problem with Autozone, I gave up and went to Honda and bought a radiator for a civic si. It cost about $225 but I went back to Autozone 4 times and they still couldnt get it right, with the radiator or hoses.</TD></TR></TABLE>maybe I should try napa they never did me wrong
Re: (93Civac)
I may live in the middle of nowhere but we have a carquest here and it's the best when it comes to Honda parts. Even the Honda delear sent me there once
BTW we don't have an autozone or discount auto...
Re: (wheelmanbg)
its pretty damn simple solution get some rad hose clamps and just tighten the pissoutta them so they are tight against the rad inlet i did this when i had my stock civic rad with my b18b swap. i never had a problem
Re: (92civichatch1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civichatch1 »</TD></TR><TR><TD CLASS="quote">its pretty damn simple solution get some rad hose clamps and just tighten the pissoutta them so they are tight against the rad inlet i did this when i had my stock civic rad with my b18b swap. i never had a problem</TD></TR></TABLE>I tried that they still leaked....NEXT
SilvrCiv99
08-02-2009 10:07 AM
streetracerof06
02-13-2006 01:14 PM
