Gas Gauge HELP
Gas Gauge HELP
Just got done swaping a GSR cluster into my EG and all the wiring is correct im 110% sure and the gas gauge wont read right (its all the way below "e") went and filled the tank to full and still reads below "e".....is there something that i have to reset like a fuse
Re: Gas Gauge HELP (kid-crx)
had the same problem wit mi si cluster just left it like that and i jus waited till the gas light goes on to fill that badboy up
I would check the year of the cluster and if it is jdm or not. I know you have the same problem if you put a 98-01 jdm itr cluster in a usdm 94-97 integra.
Re: Gas Gauge HELP (sheekdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheekdude »</TD></TR><TR><TD CLASS="quote">I would check the year of the cluster and if it is jdm or not. I know you have the same problem if you put a 98-01 jdm itr cluster in a usdm 94-97 integra.</TD></TR></TABLE>
thats the problem what do u have to do to fix that???
Uneekpinoysk8er
01-01-2004 08:15 PM
jdmhondageek
03-19-2002 07:57 PM
