***remove motor mount?***
I got a '92 Si. The motor mount thats to the right & down low. Its like a bracket bolted to the block, then bolts under the frame rail.
Can i remove it? What if i put in poly inserts......
Re: ***remove motor mount?*** (sik94hatch)
not quite sure what you are trying to do... i know you're talking about the driver side mount, but not sure what you are trying to do with it...post somemore info and i'll be happy to help if i can
Re: ***remove motor mount?*** (thahuhstunna)
Ya, its on the drivers side. Down low, not the top one....
CAN I REMOVE IT? Will i have to put in poly inserts on the other mounts?
that i belieive from your description is the drivers torque mount, you can remove it if you want, i removed mine and filled the rubber peice that always breaks with 3m window weld and let it dry for 2 days then reinstalled it but some people just leave them off
ConceptVBS
Honda Civic (2001 - 2005)
04-17-2014 06:14 AM
imadigitalgod
05-29-2010 11:32 PM
