Can you swap transmissions?
yeah my question is can you swap out a D16z6's automatic transmission with a standard transmission? basically is it a swap out/put in kind of job? and also what do you need to swap out the transmission also ive heard a lot about you need to reposition the brake pedal..? is that true? thanks
Re: Can you swap transmissions? (aallbbeerrtttttt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt »</TD></TR><TR><TD CLASS="quote">you're gonna first need to search
then in short, you would need
-tranny
-shift linkage
-starter
-clutch pedal assembly
-brake pedal assembly
-other crap</TD></TR></TABLE>
EDIT: here you go, i happened to be a little bored... https://honda-tech.com/zerothread?id=1316692
-tranny
-shift linkage
-starter
