02 sensor heater wire ?
witch of the two black wires is the heater wire on the 02 sensor ? the one under the green . or under the white ?
car harness side of the O2 connectors, looking into the connector on the open side. (ie plugs not wires)
AB
CD
A=grn/wht - grn - O2 gnd
B=white - white - O2 signal
C=orn/blk - black - heater neg control
D=yel/blk - black - heater pos
(wire colors are for an EG)
AB
CD
Re: (pdiggitydogg)
actually the 2 black wires on the 02 sensor are both heater wires and the polarity does NOT matter
this is straight from the denso instructions
black - heater
black - heater
white - signal
green - ground
/\ beat me to it
black - heater
black - heater
white - signal
green - ground
/\ beat me to it
Re: (JdmB16Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">honestly, its been so long i dont even remember which it was</TD></TR></TABLE>
1 would make sense. 41 wouldn't. 1 is the O2 sensor portion which matters which wire is which, 41 is the heater which doesn't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmB16Eg6 »</TD></TR><TR><TD CLASS="quote">i throw out a low voltage code, dunno if its the o2 sensor or the heater wires</TD></TR></TABLE>
Isn't low voltage an O2 signal code?
Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">
Isn't low voltage an O2 signal code?</TD></TR></TABLE>
i dont know what it means
Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">Isn't low voltage an O2 signal code?</TD></TR></TABLE>
It usually is.
It usually is.
Re: (JdmB16Eg6)
the only O2 CEL I can find that includes "low voltage" is about the O2 signal not the heater. The O2 signal wires are polarity sensitive.
I'm back to my original statement... reversing the heater wires will not result in a CEL.
Re: (Relic1)
i recently swapped a b16 sirII into my 92 hatch...have not wired in the 4 wire o2 yet but could i wire the black wires together and run the green and white where ever they are supposed to go?
Re: (Relic1)
i just wired my o2 last nite and it is workin fine now...i wired one of the black wires to one the yellow/black wires into the empty plug on the strut tower...the other black wire to the orange/black wire on plug A on the strut tower pass. side...ran the white wire into the stock white one wire on the engine harness...and green to thermostat ground...and everything works great
HXMan
04-26-2002 08:13 AM
