d16y8 rev limit
d16y8 rev limit
i got a d16y8 and ive heard a lot of different rev points
my tach goes to 6900 rpms
i heard lots of people say take it to 7100 or even 7400
where should i shift to get the most out of it w/o losing power?
Re: d16y8 rev limit (speedysohc)
on my y8 my vafc read 71** as my rev limit in neutral and i think i a lil higher when i was in gear but never really checked it (hit it a couple of times but on accident but not really sure, it felt a lil higher than 7100) i always shifted right before 7K like around 6800-6900
Re: d16y8 rev limit (props_honda85)
i used to think mine hit around 7200, but i just found out recently that i can shift at like 7400 w/o hitting the limiter and it doesnt feel like im losing any power
Re: (garrettej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garrettej8 »</TD></TR><TR><TD CLASS="quote">the d16y8 rev limiter starts at 7200rpm if that answers your question...</TD></TR></TABLE>
Re: (bsixteen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sandmaggot »</TD></TR><TR><TD CLASS="quote">Rev till you hit the limiter or untill you feel the power band drop, then you wut your limit is. </TD></TR></TABLE>
not smart, tachs aren't always 100% accurate :-\ Especially at higher RPMs
like for example, I've brought my D16Z6 to 8k on the tach a few times..but I doubt it could do that because as far as I know the ECU is normal and rev limiter is 7200, so obviously there's some tach error there - and wherever u shift around there u'll still be in the power band no problem..
Re: (t0p_sh0tta)
Right, redline is the safe place to stop and rev limit is for idiots that think their stock engine will keep getting more power as the revs go up.
Re: (onefast93sol)
wtf are you talking about. the rev limiter cuts off fuel so u get the bouncy tach. unless your downshifting and over rev, your not gonna blow a motor by hitting the rev limiter a bazillion times (figure of speech). so the powerband peaks out at 6600, some people take it further so when they shift they're in the appropriate rpms for that power. geeez.
Well, you can shift at the redline, still be in vtec range. Or you can go past the to the limiter, lose power, put extra wear on the engine. There's no point to going to the rev limiter, but like they said it's set at 7200.
6600: peak power
6900: redline
7200: limiter
6600: peak power
6900: redline
7200: limiter
Re: (Sandmaggot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garrettej8 »</TD></TR><TR><TD CLASS="quote">the d16y8 rev limiter starts at 7200rpm if that answers your question...</TD></TR></TABLE> yeah thats a great to to make ur valves float
Re: (speedysohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedysohc »</TD></TR><TR><TD CLASS="quote">you'd be suprised that little motor gets up </TD></TR></TABLE>
ive rarely drive it up there cause it just gets loud and it doesnt feel like im getting anywhere?
No, I really doubt it's making power up there. It peaks at 6600 then starts losing power... If Honda engineered it to still be making power at that rpm, the redline would be higher...
