D16z6 intake manifold on a D15B7 engine?
The z6 mani will bolt on from what I have read, but I'm curious if I need to upgrade anything else like fuel injectors for the z6, fuel rail, throttle body..
Or is it all interchangeable with each other?
Thanks for any help.
Re: D16z6 intake manifold on a D15B7 engine? (jefe)
Just curious what is the reason for the swap? If I had my 92-95 civic pdf file handy I would hook you up with specs....sorry.
Re: D16z6 intake manifold on a D15B7 engine? (GTlvr82)
no real reason....something to do....i cant imagine it would make any noticeable difference...maybe a little more air flow....
i have a perfectly clean d16z6 intake manifold sitting around, thought it would be a fun quick task....
It will help out more than likely, I know swapping a Y8 manifold onto a Y7 head helped me quite a bit. I don't think you need to swap the injectors, fuel rail, etc. I used all my Y7 stuff and it worked fine. I would presume the B7 stuff would work on the Z6 as well.
Re: D16z6 intake manifold on a D15B7 engine? (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** »</TD></TR><TR><TD CLASS="quote">It will help out more than likely, I know swapping a Y8 manifold onto a Y7 head helped me quite a bit. I don't think you need to swap the injectors, fuel rail, etc. I used all my Y7 stuff and it worked fine. I would presume the B7 stuff would work on the Z6 as well. </TD></TR></TABLE>
Right on. Thanks!
Right on. Thanks!
Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">its a direct swap, use either your stuff or the z6 stuff. not going to make a noticeable differance though.</TD></TR></TABLE>
I figured as much.
I figured as much.
PrettyMuchBoned
24
04-16-2014 11:48 AM
shawnperolis
11
09-02-2010 11:42 AM
Educator
11-25-2008 07:58 AM
purple98ek
09-24-2005 08:25 PM
