transmission squeal when down shifting
I have a 1994 Civic Ex 5-speed. When I'm in 1st and shift to 2nd, at around 5,000 rpms, when you push the clutch in it makes a loud squeal like a belt squeal. When you down shift from 3rd to 2nd at around 5,000 rpms it also squeals. Also when I first crank the car and put it into reverse, it grinds going into reverse. Does any one know what might be the problem? Please help! Thanks.
Go Tigers!
Re: transmission squeal when down shifting (94JDMcivic)
grinding while going into reverse is normal. press the clutch in and shift from 1-2-R to prevent the grind.
sounds like it might be a pilot bearing, but your describtion is a bit unclear.
Go Tigers!
Re: (Formula94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Formula94 »</TD></TR><TR><TD CLASS="quote">The syncro for 2nd gear could be going bad. </TD></TR></TABLE>
it could be, but the gears would grind instead of squeal.
Re: (Bense)
check your tranny mount... it could be its broken.. causing it to squeal when u downshift at those rpm cuz the motor shifts its wieght... it happend to me just check it out..if not just take bense's advice he knows his stuff
Go Tigers!
Re: (B16CRXT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT »</TD></TR><TR><TD CLASS="quote">Throw out bearing could be going out. Only way to know for sure is to remove the tranny and check out the visible bearings.</TD></TR></TABLE>
yep, pretty much.
5 hours if taking the trans apart to see whats up > two weeks of trying to figure out wtf is going on
yep, pretty much.
DC5_lov3r
12-10-2007 05:51 PM
JDMflavor_EJ
07-12-2004 09:07 PM
