Is it ok to plug/loop these holes up?
cute little bastard
My setup is a B18C1 block with B16A head. The part where the oil filter would thread on, there are these 2 holes sticking out but there are not any lines for these 2 holes to go to. I know they're for the oil cooler or w/e on a stock GSR, but would it be ok to loop from one to the other? #11
There's also a hole right next to this on the block itself (not pictured). Not sure what its for. Could I just plug it up?
Re: Is it ok to plug/loop these holes up? (SkoundrelUSA)
http://www.acuraoemparts.com/d...ch=no
the link i provided above has the piece you need to loop it through to get coolant for the oil cooler. item #9. without it i don't think you can loop it anywhere else.
Re: Is it ok to plug/loop these holes up? (philosofy1)
right, he is saying he does not have that kind of water pipe (hah waterpipe!!) and wants to know if he can just put a hose on one side and loop it to the other.
Yes you can but then the oil cooler will not be working.
I looped mine for the same reason, but I do have an external oil cooler, although its not necessary.
cute little bastard
I think some of you guys are not thinking of the same thing as me. I'm not talking about looping the water pipe or anything.
This is what I want to do. Loop a hose from one to another like the red line in this pic. Will that be ok/safe?
YES AT LEAST I UNDERSTAND!
Like I said, I did it, its fine. You just won't have the benefit of the OEM oil cooler effects (it doesn't do much anyway)
INCNTRL4
10
06-29-2006 07:32 PM
Frozen E
16
04-25-2006 05:06 PM
