LSD question
1 Post
as in a burnout? or did you have the car jacked up and you spun it with your hand?
the transmission has a code on it...check it out. and it helps if you add details like what kind of car...what engine...auto or manual...year...
Re: LSD question (JDMbullshit)
sometimes the sticker or stamp comes off that show the tranny model and the spinning of the wheel is the wrong way to tell if you have LSD. the true way to tell is by pulling the axles out of the tranny. if there is a pin inside the differential then you have no LSD. if there is no pin and you can see right through it, then you do and go have some fun taking corners.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMbullshit »</TD></TR><TR><TD CLASS="quote">i just spun my wheel and when i did the other side didnt spin what type of trasmission is that?</TD></TR></TABLE>
Back me up on this guys... is it called planar transmission? My friend told me the technical name of most transmisions (that allow one wheel spinning), but I can't remember the name exactly.
Re: (JDMbullshit)
It's an 1/2 differential...but how that translates to FWD cars I'm not sure..
Was your car in gear when u did it?
If not, each wheel will spin independently.
It needs to be in gear (not neccessarily on, just in gear)
