will 98+ spec JDM Type R axels, half shaft, motor mounts and engine harness fit on my 99-00 Si ?
just wanted to know if these parts will all bolt on to my Si .. some say axels harness half shaft nor the motor mounts will fit.. some say i only need two si motor mounts ..
Re: will 98+ spec JDM Type R axels, half shaft, motor mounts and engine harness fit on my 99-00 Si ?
you will need to replace the hubs, or if they hubs arent interchangeable, the front knuckles from a ITR to fit the axles in your civic, the ITR mounts I beleve will not work, the Si mounts will, they HAVE to be Si mounts, or else the rear mount will not bolt up. and the typeR is obd2a I beleive, and that is hell to install a wire harness anyways just make it an OBD1 motor and be done with it.
alien
08-23-2006 01:10 AM
hypedlunatic
10-31-2004 12:19 PM
