TRY TO FIGURE THIS SH*T OUT LS-V WONT START BACK UP
heres the deal i ran it down the track.... hit third gear.... stayed in v-tec and the motor started to detonate and missfire real bad... had to coast rest of way. got to the end of the track motor seemed fine like the distributor had a brain fart. Anyways started to leave the track.. the motor starts doing it again but instantly quits and runs fine. go to get on the highway and start to pull the RPM's back up it starts detonate and crackle until i stop the car. Engine now will not re-start. 1. brand new itr distributor 2. day old msd wires 3. new plugs. 4. has fuel pressure 5. only throwing a vtec #22 code 6.not out of time at all. 7 injectors are hitting. 8 but will try to start on starter fluid. I NEED HELP BAD NO-ONE IN CINCINNATI CAN FIGURE THIS **** OUT.
Re: TRY TO FIGURE THIS SH*T OUT LS-V WONT START BACK UP (DAVID_VARNER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAVID_VARNER »</TD></TR><TR><TD CLASS="quote">I NEED HELP BAD NO-ONE IN CINCINNATI CAN FIGURE THIS **** OUT. </TD></TR></TABLE>
You probably didn't ask everybody.
Wont start huh? Does it have spark?
Re: TRY TO FIGURE THIS SH*T OUT LS-V WONT START BACK UP (Stoich EG2)
the trans ground, thermostat housing ground and the valve cover ground is all there, all the fuses are fine. .i grounded out a spark plug and it had a massive spark. you can hear the relay kick on. everything seems to be doin its job. ITS AN LS-V WITH B16 HEAD AND A P28 COMPUTER.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAVID_VARNER »</TD></TR><TR><TD CLASS="quote">the trans ground, thermostat housing ground and the valve cover ground is all there, all the fuses are fine. .i grounded out a spark plug and it had a massive spark. you can hear the relay kick on. everything seems to be doin its job. ITS AN LS-V WITH B16 HEAD AND A P28 COMPUTER. </TD></TR></TABLE>
Does it have fuel pressure?
it has plenty of fuel pressure and it hasnt jumped time. i'll do a compression test tommorrow and let you know
xKAMILxEK
09-25-2009 10:25 PM
